A mathematical model of p62-ubiquitin aggregates in autophagy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Biology Année : 2022
Aggregation of ubiquitinated cargo by oligomers of the protein p62 is an important preparatory step in cellular autophagy. In this work a mathematical model for the dynamics of these heterogeneous aggregates in the form of a system of ordinary differential equations is derived and analyzed. Three different parameter regimes are identified, where either aggregates are unstable, or their size saturates at a finite value, or their size grows indefinitely as long as free particles are abundant. The boundaries of these regimes as well as the finite size in the second case can be computed explicitly. The growth in the third case (quadratic in time) can also be made explicit by formal asymptotic methods. The qualitative results are illustrated by numerical simulations. A comparison with recent experimental results permits a partial parametrization of the model.
DDMS_M4.pdf (463.08 Ko) Télécharger le fichier
hal-02548223 , version 1 (20-04-2020)
Julia Delacour, Marie Doumic, Sascha Martens, Christian Schmeiser, Gabriele Zaffagnini. A mathematical model of p62-ubiquitin aggregates in autophagy. Journal of Mathematical Biology, 2022, 84 (3), ⟨10.1007/s00285-021-01659-2⟩. ⟨hal-02548223⟩
341 Consultations
115 Téléchargements
