Quantile Estimation Via a Combination of Conditional Monte Carlo and Randomized Quasi-Monte Carlo - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the problem of estimating the p-quantile of a distribution when observations from that distribution are generated from a simulation model. The standard estimator takes the p-quantile of the empirical distribution of independent observations obtained by Monte Carlo. As an improvement, we use conditional Monte Carlo to obtain a smoother estimate of the distribution function, and we combine this with randomized quasi-Monte Carlo to further reduce the variance. The result is a much more accurate quantile estimator, whose mean square error can converge even faster than the canonical rate of O(1/n).
HALwsc20-qcmcrqmc.pdf (177.09 Ko) Télécharger le fichier
hal-02551516 , version 1 (23-04-2020)
  • HAL Id : hal-02551516 , version 1
Marvin K Nakayama, Zachary T Kaplan, Bruno Tuffin, Pierre L'Ecuyer. Quantile Estimation Via a Combination of Conditional Monte Carlo and Randomized Quasi-Monte Carlo. Winter Simulation Conference 2020, Dec 2020, Orlando, United States. ⟨hal-02551516⟩
225 Consultations
353 Téléchargements
