WhyMP, a Formally Verified Arbitrary-Precision Integer Library - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Arbitrary-precision integer libraries such as GMP are a critical building block of computer algebra systems. GMP provides state-of-the-art algorithms that are intricate enough to justify formal verification. In this paper, we present a C library that has been formally verified using the Why3 verification platform in about four person-years. This verification deals not only with safety, but with full functional correctness. It has been performed using a mixture of mechanically checked handwritten proofs and automated theorem proving. We have implemented and verified a nontrivial subset of GMP's algorithms, including their optimizations and intricacies. Our library provides the same interface as GMP and is almost as efficient for smaller inputs. We detail our verification methodology and the algorithms we have implemented, and include some benchmarks to compare our library with GMP.
main.pdf (631.22 Ko) Télécharger le fichier
hal-02566654 , version 1 (07-05-2020)
hal-02566654 , version 2 (08-08-2020)
Guillaume Melquiond, Raphaël Rieu-Helft. WhyMP, a Formally Verified Arbitrary-Precision Integer Library. ISSAC 2020 - 45th International Symposium on Symbolic and Algebraic Computation, Jul 2020, Kalamata, Greece. pp.352-359, ⟨10.1145/3373207.3404029⟩. ⟨hal-02566654v2⟩
270 Consultations
578 Téléchargements
