PersistenceBundles: Visual Comparison of Topological Features - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Understanding the temporal evolution of topological features by means of tracking graphs is a common task, often performed using scalar field analysis. However, these graphs are either hard to interpret or capture information at a very high level that is not intuitive to the user. To bridge this gap, we propose persistenceBundles, a hierarchical edge-bundling approach for visualizing tracked features using persistence hierarchies. We demonstrate the effectiveness of our approach using the viscous finger dataset.
persistenceBundles.pdf (1.36 Mo) Télécharger le fichier
hal-02569089 , version 1 (11-05-2020)
hal-02569089 , version 2 (11-08-2020)
  • HAL Id : hal-02569089 , version 2
Adhitya Kamakshidasan, Vijay Natarajan. PersistenceBundles: Visual Comparison of Topological Features. 2020. ⟨hal-02569089v2⟩
232 Consultations
565 Téléchargements
