Optical trapping and orientation-resolved spectroscopy of europium-doped nanorods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Physics: Photonics Année : 2020
Europium-doped NaYF 4 nanorods with a high aspect ratio are optically trapped using a single fibre tip optical tweezers. Three distinct trapping positions of the nanorods are observed: in contact with the fibre tip, close to the tip and 5 µm from the tip end. The direction and polarisation-dependent Eu 3+ photoluminescence is investigated by recording the emission parallel and perpendicular to the nanorod long axis through the trapping fibre and the microscope objective, respectively. These spectroscopic measurements permit an unambiguous determination of the nanorod orientation.
Kumar_rev.pdf (4.06 Mo) Télécharger le fichier
hal-02569492 , version 1 (23-09-2020)
Aashutosh Kumar, Jeongmo Kim, Khalid Lahlil, Gwénäelle Julié, Síle Nic Chormaic, et al.. Optical trapping and orientation-resolved spectroscopy of europium-doped nanorods. Journal of Physics: Photonics, 2020, 2 (2), pp.025007. ⟨10.1088/2515-7647/ab83e3⟩. ⟨hal-02569492⟩
57 Consultations
33 Téléchargements
