Text Corpora and the Challenge of Newly Written Languages - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Text corpora represent the foundation on which most natural language processing systems rely. However, for many languages, collecting or building a text corpus of a sufficient size still remains a complex issue, especially for corpora that are accessible and distributed under a clear license allowing modification (such as annotation) and further resharing. In this paper, we review the sources of text corpora usually called upon to fill the gap in low-resource contexts, and how crowdsourcing has been used to build linguistic resources. Then, we present our own experiments with crowdsourcing text corpora and an analysis of the obstacles we encountered. Although the results obtained in terms of participation are still unsatisfactory, we advocate that the effort towards a greater involvement of the speakers should be pursued, especially when the language of interest is newly written.
ccurl2020_kfam.pdf (202.06 Ko) Télécharger le fichier
hal-02611209 , version 1 (18-05-2020)
  • HAL Id : hal-02611209 , version 1
Alice Millour, Karën Fort. Text Corpora and the Challenge of Newly Written Languages. 1st Joint SLTU and CCURL Workshop (SLTU-CCURL 2020), May 2020, Marseille, France. ⟨hal-02611209⟩
118 Consultations
130 Téléchargements
