Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Journal articles
Transcription and Separation of Drum Signals From Polyphonic Music
Abstract : The purpose of this article is to present new advances in music transcription and source separation with a focus on drum signals. A complete drum transcription system is described, which combines information from the original music signal and a drum track enhanced version obtained by source separation. In addition to efficient fusion strategies to take into account these two complementary sources of information, the transcription system integrates a large set of features, optimally selected by feature selection. Concurrently, the problem of drum track extraction from polyphonic music is tackled both by proposing a novel approach based on harmonic/noise decomposition and time/frequency masking and by improving an existing Wiener filtering-based separation method. The separation and transcription techniques presented are thoroughly evaluated on a large public database of music signals. A transcription accuracy between 64.5% and 80.3% is obtained, depending on the drum instrument, for well-balanced mixes, and the efficiency of our drum separation algorithms is illustrated in a comprehensive benchmark.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-02652666
Contributor : Gaël RICHARD Connect in order to contact the contributor
Submitted on : Friday, May 29, 2020 - 7:56:32 PM
Last modification on : Tuesday, October 19, 2021 - 11:16:16 AM
Links full text
Identifiers
Collections
Citation
Olivier Gillet, Gael Richard. Transcription and Separation of Drum Signals From Polyphonic Music. IEEE Transactions on Audio, Speech and Language Processing, Institute of Electrical and Electronics Engineers, 2008, ⟨10.1109/TASL.2007.914120⟩. ⟨hal-02652666⟩
Share
Metrics
Record views
28
