PAC-Bayes unleashed: generalisation bounds with unbounded losses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Entropy Année : 2021
We present new PAC-Bayesian generalisation bounds for learning problems with unbounded loss functions. This extends the relevance and applicability of the PAC-Bayes learning framework, where most of the existing literature focuses on supervised learning problems where the loss function is bounded (typically assumed to take values in the interval [0;1]). In order to relax this assumption, we propose a new notion called the \emph{special boundedness condition}, which effectively allows the range of the loss to depend on each predictor. Based on this new notion we derive a novel PAC-Bayesian generalisation bound for unbounded loss functions, and we instantiate it on a linear regression problem. To make our theory usable by the largest audience possible, we include discussions on actual computation, practicality and limitations of our assumptions.
2006.07279.pdf (472.92 Ko) Télécharger le fichier
hal-02872173 , version 1 (17-06-2020)
Maxime Haddouche, Benjamin Guedj, Omar Rivasplata, John Shawe-Taylor. PAC-Bayes unleashed: generalisation bounds with unbounded losses. Entropy, 2021, ⟨10.3390/e23101330⟩. ⟨hal-02872173⟩
77 Consultations
219 Téléchargements
