Are cookie banners indeed compliant with the law? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Technology and Regulation Année : 2020
In this paper, we describe how cookie banners, as a consent mechanism in web applications, should be designed and implemented to be compliant with the ePrivacy Directive and the GDPR, defining 22 legal requirements. While some are provided by legal sources, others result from the domain expertise of computer scientists. We perform a technical assessment of whether technical (with computer science tools), manual (with a human operator) or user studies verification is needed. We show that it is not possible to assess legal compliance for the majority of requirements because of the current architecture of the web. With this approach, we aim to support policy makers assessing compliance in cookie banners, especially under the current revision of the EU ePrivacy framework.
2020-09-22-journal.pdf (4.14 Mo) Télécharger le fichier
hal-02875447 , version 1 (19-06-2020)
hal-02875447 , version 2 (23-09-2020)
Cristiana Santos, Nataliia Bielova, Célestin Matte. Are cookie banners indeed compliant with the law?: Deciphering EU legal requirements on consent and technical means to verify compliance of cookie banners. Technology and Regulation, 2020, 2020, pp.91-135. ⟨10.26116/TECHREG.2020.009⟩. ⟨hal-02875447v2⟩
2551 Consultations
2902 Téléchargements
