Boosting Verifiable Computation on Encrypted Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the setting in which an untrusted server stores a collection of data and is asked to compute a function over it. In this scenario, we aim for solutions where the untrusted server does not learn information about the data and is prevented from cheating. This problem is addressed by verifiable and private delegation of computation, proposed by Gennaro, Gentry and Parno (CRYPTO'10), a notion that is close to both the active areas of homomorphic encryption and verifiable computation (VC). However, in spite of the efficiency advances in the respective areas, VC protocols that guarantee privacy of the inputs are still expensive. The only exception is a protocol by Fiore, Gennaro and Pastro (CCS'14) that supports arithmetic circuits of degree at most 2. In this paper we propose new efficient protocols for VC on encrypted data that improve over the state of the art solution of Fiore et al. in multiple aspects. First, we can support computations of degree higher than 2. Second, we achieve public delegatability and public verifiability whereas Fiore et al. need the same secret key to encode inputs and verify outputs. Third, we achieve a new property that guarantees that verifiers can be convinced about the correctness of the outputs without learning information on the inputs. The key tool to obtain our new protocols is a new SNARK that can efficiently handle computations over a quotient polynomial ring, such as the one used by Ring-LWE somewhat homomorphic encryption schemes. This SNARK in turn relies on a new commit-and-prove SNARK for proving evaluations on the same point of several committed polynomials. We propose a construction of this scheme under an extractability assumption over bilinear groups in the random oracle model.
2020-132.pdf (499.99 Ko) Télécharger le fichier
hal-02894482 , version 1 (05-11-2020)
Dario Fiore, Anca Nitulescu, David Pointcheval. Boosting Verifiable Computation on Encrypted Data. PKC 2020 - 23rd IACR International Conference on Practice and Theory of Public-Key Cryptography, Jun 2020, Edinburgh / Virtual, United Kingdom. pp.124-154, ⟨10.1007/978-3-030-45388-6_5⟩. ⟨hal-02894482⟩
232 Consultations
371 Téléchargements
