Provenance for the Description Logic ELHr - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We address the problem of handling provenance information in ELHr ontologies. We consider a setting recently introduced for ontology-based data access, based on semirings and extending classical data provenance, in which ontology axioms are annotated with provenance tokens. A consequence inherits the provenance of the axioms involved in deriving it, yielding a provenance polynomial as annotation. We analyse the semantics for the ELHr case and show that the presence of conjunctions poses various difficulties for handling provenance, some of which are mitigated by assuming multiplicative idempotency of the semiring. Under this assumption, we study three problems: ontology completion with provenance, computing the set of relevant axioms for a consequence, and query answering.
paper2243.pdf (308.62 Ko) Télécharger le fichier
hal-02899464 , version 1 (15-07-2020)
Camille Bourgaux, Ana Ozaki, Rafael Peñaloza, Livia Predoiu. Provenance for the Description Logic ELHr. IJCAI-PRICAI-20 - Twenty-Ninth International Joint Conference on Artificial Intelligence and Seventeenth Pacific Rim International Conference on Artificial Intelligence, Jul 2020, Yokohama, Japan. pp.1862-1869, ⟨10.24963/ijcai.2020/258⟩. ⟨hal-02899464⟩
69 Consultations
205 Téléchargements
