A functional structural model of grass development based on metabolic regulation and coordination rules - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Experimental Botany Année : 2020
Shoot architecture is a key component of the interactions between plants and their environment. We present a novel model of grass, which fully integrates shoot morphogenesis and the metabolism of carbon (C) and nitrogen (N) at organ scale, within a three-dimensional representation of plant architecture. Plant morphogenesis is seen as a self-regulated system driven by two main mechanisms. First, the rate of organ extension and the establishment of architectural traits are regulated by concentrations of C and N metabolites in the growth zones and the temperature. Second, the timing of extension is regulated by rules coordinating successive phytomers instead of a thermal time schedule. Local concentrations are calculated from a model of C and N metabolism at organ scale. The three-dimensional representation allows the accurate calculation of light and temperature distribution within the architecture. The model was calibrated for wheat (Triticum aestivum) and evaluated for early vegetative stages. This approach allowed the simulation of realistic patterns of leaf dimensions, extension dynamics, and organ mass and composition. The model simulated, as emergent properties, plant and agronomic traits. Metabolic activities of growing leaves were investigated in relation to whole-plant functioning and environmental conditions. The current model is an important step towards a better understanding of the plasticity of plant phenotype in different environments.
Gauthier_2020_A functional structural model of grass development based on metabolic regulation and coordination rules.pdf (1.84 Mo) Télécharger le fichier
hal-02903070 , version 1 (08-12-2020)
Marion Gauthier, Romain Barillot, Anne Schneider, Camille Chambon, Christian Fournier, et al.. A functional structural model of grass development based on metabolic regulation and coordination rules. Journal of Experimental Botany, 2020, 71 (18), pp.5454-5468. ⟨10.1093/jxb/eraa276⟩. ⟨hal-02903070⟩
204 Consultations
90 Téléchargements
