Termination of graph rewriting systems through language theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Guillaume Bonfante
  • Fonction : Auteur
  • PersonId : 830993
Miguel Couceiro
The termination issue that we tackle is rooted in Natural Language Processing where computations are performed by graph rewriting systems (GRS) that may contain a large number of rules, often in the order of thousands. This asks for algorithmic procedures to verify the termination of such systems. The notion of graph rewriting that we consider does not make any assumption on the structure of graphs (they are not "term graphs", "port graphs" nor "drags"). This lack of algebraic structure led us to proposing two orders on graphs inspired from language theory: the matrix multiset-path order and the rational embedding order. We show that both are stable by context, which we then use to obtain the main contribution of the paper: under a suitable notion of "interpretation", a GRS is terminating if and only if it is compatible with an interpretation.
RewritingAalgos_rev.pdf (349.12 Ko) Télécharger le fichier
hal-02912877 , version 1 (07-08-2020)
  • HAL Id : hal-02912877 , version 1
Guillaume Bonfante, Miguel Couceiro. Termination of graph rewriting systems through language theory. ALGOS 2020 - 1st International Conference on Algebras, Graphs and Ordered Sets, Aug 2020, Nancy, France. ⟨hal-02912877⟩
66 Consultations
89 Téléchargements
