AutoGain: Gain Function Adaptation with Submovement Efficiency Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A well-designed control-to-display gain function can improve pointing performance with indirect pointing devices like track-pads. However, the design of gain functions is challenging and mostly based on trial and error. AutoGain is a novel method to individualize a gain function for indirect pointing devices in contexts where cursor trajectories can be tracked. It gradually improves pointing efficiency by using a novel submovement-level tracking+optimization technique that minimizes aiming error (undershooting/overshooting) for each submovement. We first show that AutoGain can produce, from scratch, gain functions with performance comparable to commercial designs, in less than a half-hour of active use. Second, we demonstrate AutoGain's applicability to emerging input devices (here, a Leap Motion controller) with no reference gain functions. Third, a one-month longitudinal study of normal computer use with AutoGain showed performance improvements from participants' default functions.
CHI2020_AutoGain.pdf (1.2 Mo) Télécharger le fichier
hal-02918581 , version 1 (20-08-2020)
Byungjoo Lee, Mathieu Nancel, Sunjun Kim, Antti Oulasvirta. AutoGain: Gain Function Adaptation with Submovement Efficiency Optimization. Proceedings of the 2020 CHI Conference on Human Factors in Computing Systems (CHI '20), Apr 2020, Honolulu, United States. pp.1-12, ⟨10.1145/3313831.3376244⟩. ⟨hal-02918581⟩
118 Consultations
162 Téléchargements
