Metric learning loss functions to reduce domain mismatch in the x-vector space for language recognition - Inria - Institut national de recherche en sciences et technologies du numérique
State-of-the-art language recognition systems are based on dis-criminative embeddings called x-vectors. Channel and gender distortions produce mismatch in such x-vector space where em-beddings corresponding to the same language are not grouped in an unique cluster. To control this mismatch, we propose to train the x-vector DNN with metric learning objective functions. Combining a classification loss with the metric learning n-pair loss allows to improve the language recognition performance. Such a system achieves a robustness comparable to a system trained with a domain adaptation loss function but without using the domain information. We also analyze the mismatch due to channel and gender, in comparison to language proximity, in the x-vector space. This is achieved using the Maximum Mean Discrepancy divergence measure between groups of x-vectors. Our analysis shows that using the metric learning loss function reduces gender and channel mismatch in the x-vector space, even for languages only observed on one channel in the train set.
raphael_interspeech_v9.pdf (215.38 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-02920460 , version 1 (24-08-2020)
  • HAL Id : hal-02920460 , version 1
Raphaël Duroselle, Denis Jouvet, Irina Illina. Metric learning loss functions to reduce domain mismatch in the x-vector space for language recognition. INTERSPEECH 2020, Oct 2020, Shangaï / Virtual, China. ⟨hal-02920460⟩
344 Consultations
444 Téléchargements
More
