The MID property for a second-order neutral time-delay differential equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper considers the Multiplici- ty-Induced-Dominancy (MID) property for second order neutral time-delay differential equations. Necessary and sufficient conditions for the exis- tence of a root of maximal multiplicity are given in terms of this root and the parameters (includ- ing the delay) of the given equation. Links with dominancy of this root and with the exponential stability property of the solution of the consid- ered equations are given. Finally, we illustrate the obtained results on the classical oscillator control problem.
MID_Neutral_2nd_Order_ICSTCC_2020 (4).pdf (501.03 Ko) Télécharger le fichier
hal-02934532 , version 1 (09-09-2020)
Amina Benarab, Islam Boussaada, Catherine Bonnet, Karim Trabelsi, Guilherme Mazanti. The MID property for a second-order neutral time-delay differential equation. 24th International Conference on System Theory, Control and Computing (ICSTCC 2020), Oct 2020, Sinaia, Romania. ⟨10.1109/ICSTCC50638.2020.9259779⟩. ⟨hal-02934532⟩
314 Consultations
368 Téléchargements
