The influence of the brittle-ductile transition zone on aftershock and foreshock occurrence - Archive ouverte HAL Access content directly
Journal Articles Nature Communications Year : 2020
(1) , (1) , (2, 3) , (4)
1
2
3
4
Aftershock occurrence is characterized by scaling behaviors with quite universal exponents. At the same time, deviations from universality have been proposed as a tool to discriminate aftershocks from foreshocks. Here we show that the change in rheological behavior of the crust, from velocity weakening to velocity strengthening, represents a viable mechanism to explain statistical features of both aftershocks and foreshocks. More precisely, we present a model of the seismic fault described as a velocity weakening elastic layer coupled to a velocity strengthening visco-elastic layer. We show that the statistical properties of after-shocks in instrumental catalogs are recovered at a quantitative level, quite independently of the value of model parameters. We also find that large earthquakes are often anticipated by a preparatory phase characterized by the occurrence of foreshocks. Their magnitude distribution is significantly flatter than the aftershock one, in agreement with recent results for forecasting tools based on foreshocks.
2020-NatComm - The influence of the brittle-ductile transition zone on aftershock and foreshock occurrence.pdf (1.14 Mo) Télécharger le fichier
Dates and versions
hal-02942365 , version 1 (17-09-2020)
Identifiers
Cite
Giuseppe Petrillo, Eugenio Lippiello, François P. Landes, Alberto Rosso. The influence of the brittle-ductile transition zone on aftershock and foreshock occurrence. Nature Communications, 2020, 11 (1), ⟨10.1038/s41467-020-16811-7⟩. ⟨hal-02942365⟩
61 View
376 Download
Share
