Visual Abstraction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2020
Visual Abstraction
Min Chen
  • Fonction : Auteur
  • PersonId : 755831
  • IdRef : 135605172
Tobias Isenberg
In this chapter we revisit the concept of abstraction as it is used in visualization and put it on a solid formal footing. While the term abstraction is utilized in many scientific disciplines, arts, as well as everyday life, visualization inherits the notion of data abstraction or class abstraction from computer science, topological abstraction from mathematics, and visual abstraction from arts. All these notions have a lot in common, yet there is a major discrepancy in the terminology and basic understanding about visual abstraction in the context of visualization. We thus root the notion of abstraction in the philosophy of science, clarify the basic terminology, and provide crisp definitions of visual abstraction as a process. Furthermore, we clarify how it relates to similar terms often used interchangeably in the field of visualization. Visual abstraction is characterized by a conceptual space where this process exists, by the purpose it should serve, and by the perceptual and cognitive qualities of the beholder. These characteristics can be used to control the process of visual abstraction to produce effective and informative visual representations.
Informatique
Viola_2020_VA.pdf (8.2 Mo) Télécharger le fichier
Format : Figure, Image
hal-02944201 , version 1 (21-09-2020)
Ivan Viola, Min Chen, Tobias Isenberg. Visual Abstraction. Min Chen; Helwig Hauser; Penny Rheingans; Gerik Scheuermann. Foundations of Data Visualization, Springer International Publishing, pp.15--37, 2020, 978-3-030-34444-3. ⟨10.1007/978-3-030-34444-3_2⟩. ⟨hal-02944201⟩
101 Consultations
403 Téléchargements
