Analysis of the Delayed Central Nervous System Action in the Regulation of a Third-order Muscle-Tendon Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents the analysis of a third-order linear time-invariant delay differential equation representing the regulation of a muscle-tendon system. The Central Nervous System action is modeled as a delayed proportional-derivative controller exploiting the multiplicity-induced-dominancy property. The stability analysis is illustrated via the software P3δ.
Muscle_ICSTCC-2020.pdf (1.11 Mo) Télécharger le fichier
hal-02944531 , version 1 (21-09-2020)
Ali El Ati, Islam Boussaada, Silviu-Iulian Niculescu, Pierre-Henry Poret. Analysis of the Delayed Central Nervous System Action in the Regulation of a Third-order Muscle-Tendon Model. 24th International Conference on System Theory, Control and Computing (ICSTCC 2020), Oct 2020, Sinaia, Romania. ⟨10.1109/icstcc50638.2020.9259775⟩. ⟨hal-02944531⟩
178 Consultations
123 Téléchargements
