Querying and Repairing Inconsistent Prioritized Knowledge Bases: Complexity Analysis and Links with Abstract Argumentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Camille Bourgaux
In this paper, we explore the issue of inconsistency handling over prioritized knowledge bases (KBs), which consist of an ontology, a set of facts, and a priority relation between conflicting facts. In the database setting, a closely related scenario has been studied and led to the definition of three different notions of optimal repairs (global, Pareto, and completion) of a prioritized inconsistent database. After transferring the notions of globally-, Pareto- and completion-optimal repairs to our setting, we study the data complexity of the core reasoning tasks: query entailment under inconsistency-tolerant semantics based upon optimal repairs, existence of a unique optimal repair, and enumeration of all optimal repairs. Our results provide a nearly complete picture of the data complexity of these tasks for ontologies formulated in common DL-Lite dialects. The second contribution of our work is to clarify the relationship between optimal repairs and different notions of extensions for (set-based) argumentation frameworks. Among our results, we show that Pareto-optimal repairs correspond precisely to stable extensions (and often also to preferred extensions), and we propose a novel semantics for prioritized KBs which is inspired by grounded extensions and enjoys favourable computational properties. Our study also yields some results of independent interest concerning preference-based argumentation frameworks.
BieBou-KR20 (1).pdf (325.88 Ko) Télécharger le fichier
hal-02947251 , version 1 (24-09-2020)
  • HAL Id : hal-02947251 , version 1
Meghyn Bienvenu, Camille Bourgaux. Querying and Repairing Inconsistent Prioritized Knowledge Bases: Complexity Analysis and Links with Abstract Argumentation. KR 2020 - 17th International Conference on Principles of Knowledge Representation and Reasoning, Sep 2020, Rhodes, Greece. pp.141-151. ⟨hal-02947251⟩
86 Consultations
116 Téléchargements
