Interpretable privacy with optimizable utility - Archive ouverte HAL Access content directly
Conference Papers Year :
(1) , (1)
1
In this position paper, we discuss the problem of specifying privacy requirements for machine learning based systems, in an inter-pretable yet operational way. Explaining privacy-improving technology is a challenging problem, especially when the goal is to construct a system which at the same time is interpretable and has a high performance. In order to address this challenge, we propose to specify privacy requirements as constraints, leaving several options for the concrete implementation of the system open, followed by a constraint optimization approach to achieve an efficient implementation also, next to the interpretable privacy guarantees.
ipcp.pdf (202.05 Ko) Télécharger le fichier
Dates and versions
hal-02950994 , version 1 (28-09-2020)
Identifiers
  • HAL Id : hal-02950994 , version 1
Cite
Jan Ramon, Moitree Basu. Interpretable privacy with optimizable utility. ECML/PKDD 2020 - Workshop on eXplainable Knowledge Discovery in Data mining, Sep 2020, Ghent / Virtual, Belgium. ⟨hal-02950994⟩
190 View
162 Download
Share
