Template based model engineering in UML - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Model-based engineering (MBE) contributes a lot to software reuse by abstracting technology independent models, their capitalization and then their reuse to pro- duce systems, ensuring early composition and checking capabilities. One step further, it was recognized that models could be parameterized in order to capture re- current modeling patterns. This led to the concept of "model template" as offered in UML. In this paper we con- centrate on engineering practices and operators which derive from the adoption of this concept, specifically in the case of "aspectual templates", where parameters form full models. As a first step, we show the consequent partitioning of modeling spaces into two subspaces: one dedicated to template modelers ("model for reuse"), the other one dedicated to application modelers ("model by reuse"). Respective activities are identified, but also back-and-forth between them. From this, engineering operators are isolated and formally specified. Finally, reusable technology within Eclipse is offered.
Fichier non déposé
hal-02951535 , version 1 (28-09-2020)
Gilles Vanwormhoudt, Matthieu Allon, Olivier Caron, Bernard Carré. Template based model engineering in UML. MoDELS '20 ACM/IEEE 23rd International Conference on Model Driven Engineering Languages and Systems, Oct 2020, Montreal, Canada. ⟨10.1145/3365438.3410988⟩. ⟨hal-02951535⟩
169 Consultations
0 Téléchargements
