The effects of repetitive neck-muscle vibration on postural disturbances after a chronic stroke - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neurophysiologie Clinique = Clinical Neurophysiology Année : 2020
Objective. - We aimed to test a repeated program of vibration sessions of the neck muscles (rNMV) on postural disturbances and spatial perception in patients with right (RBD) versus left (LBD) vascular brain damage. Methods. -Thirty-two chronic stroke patients (mean age 60.9 +/- 10 yrs and mean time since stroke 4.9 +/- 4 yrs), 16 RBD and 16 LBD, underwent a program of 10 sessions of NMV over two weeks. Posturography parameters (weight-bearing asymmetry (WBA), Xm, Ym, and surface), balance rating (Berg Balance Scale (BBS), Timed Up and Go (TUG)), space representation (subjective straight ahead (SSA), longitudinal body axis (LBA), subjective visual vertical (SW)), and post-stroke deficiencies (motricity index, sensitivity, and spasticity) were tested and the data analyzed by ANOVA or a linear rank-based model, depending on whether the data were normally distributed, with lesion side and time factor (D-15, D0, D15, D21, D45). Results. -The ANOVA revealed a significant interaction between lesion side and time for WBA (P< 0.0001) with a significant shift towards the paretic lower limb in the RBD patients only (P=0.0001), whereas there was no effect in the LBD patients (P=0.98). Neither group showed a significant modification of spatial representation. Nonetheless, there was a significant improvement in motricity (P=0.02), TUG (P=0.0005), and BBS (P< 0.0001) in both groups at the end of treatment and afterwards. Conclusions. - rNMV appeared to correct WBA in RBD patients only. This suggests that rNMV could be effective in treating sustainable imbalance due to spatial cognition disorders. (C) 2020 Elsevier Masson SAS. All rights reserved.
S0987705320300137.pdf (579.7 Ko) Télécharger le fichier
hal-02958924 , version 1 (14-09-2022)
Paternité - Pas d'utilisation commerciale
Karim Jamal, Stéphanie Leplaideur, Chloé Rousseau, Sébastien Cordillet, Annelise Moulinet Raillon, et al.. The effects of repetitive neck-muscle vibration on postural disturbances after a chronic stroke. Neurophysiologie Clinique = Clinical Neurophysiology, 2020, 50 (4), pp.269-278. ⟨10.1016/j.neucli.2020.01.005⟩. ⟨hal-02958924⟩
82 Consultations
67 Téléchargements
