AdoBPRIM: Towards a New Healthcare Risk-aware Business Process Management Tool - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Performing risk management in healthcare facilities is particularly difficult due to the highly dynamic, complex, and multi-disciplinary nature of healthcare processes like the Medication Use Process (MUP). Risk-aware Business Process Management (R-BPM) is a promising approach to obtain a better understanding of such processes by identifying and analyzing corresponding risks. However, not all R-BPM approaches perform well in capturing the complexity of clinical processes. In this work, we introduce a new R-BPM framework called BPRIM that allows the identification and the analysis of medication error risks related to the complex medication use process. BPRIM is implemented using the ADOxx meta-modelling platform and then tested in a real case study. The tool is specific to the case study, but the framework can be used also in other healthcare processes.
AdoBPRIM-Towards-a-New-Healthcare-Risk-aware-Business-Process-Management-Tool.pdf (889.96 Ko) Télécharger le fichier
hal-02960115 , version 1 (07-10-2020)
Rafika Thabet, Amine Boufaied, Elyes Lamine, Dominik Bork, Ouajdi Korbaa, et al.. AdoBPRIM: Towards a New Healthcare Risk-aware Business Process Management Tool. HEALTHINF 2020 - 13th International Conference on Health Informatics, Feb 2020, La Valette, Malta. pp.498-505, ⟨10.5220/0008977604980505⟩. ⟨hal-02960115⟩
178 Consultations
214 Téléchargements
