Some Specific Aspects Related To The Use Of The Artificial Compressibility Methods To Simulate Unsteady Flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The artificial compressibility method is applied to simulate non-reactive and reactive flows with incompressible and infinite-rate chemistry assumptions. To validate the implemented time-accurate approach, the resulting code is used to calculate three different flow regimes: an unsteady non-reactive flow past a circular cylinder, a steady diffusionTsuji flame and an unsteady buoyant diffusion flame.As expected, the results evidence the strong dependence of the convergence rate to the artificial compressibility factor. They also show the ability of this approach to describe the circular cylinder wake unsteadiness as well as the flame shape of the steady diffusion flame. In return, the correct prediction of the low frequency instability known to be featured by unsteady buoyant diffusion flames is presently out of reach of the present version of the methodology.
CSP_107_final-ok.pdf (1.14 Mo) Télécharger le fichier
hal-02965305 , version 1 (06-10-2021)
Mariovane Donini, Fernando Fachini, Cesar Cristaldo, Pascal Bruel. Some Specific Aspects Related To The Use Of The Artificial Compressibility Methods To Simulate Unsteady Flows. MHMT'20 - 5th World Congress on Momentum, Heat and Mass Transfer, Oct 2020, Lisbonne / Virtual, Pitcairn Islands. ⟨10.11159/CSP20.107⟩. ⟨hal-02965305⟩
67 Consultations
50 Téléchargements
