Volume Sweeping: Learning Photoconsistency for Multi-View Shape Reconstruction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 2021
We propose a full study and methodology for multi-view stereo reconstruction with performance capture data. Multi-view 3D reconstruction has largely been studied with general, high resolution and high texture content inputs, where classic low-level feature extraction and matching are generally successful. However in performance capture scenarios, texture content is limited by wider angle shots resulting in smaller subject projection areas, and intrinsically low image content of casual clothing. We present a dedicated pipeline, based on a per-camera depth map sweeping strategy, analyzing in particular how recent deep network advances allow to replace classic multi-view photoconsistency functions with one that is learned. We show that learning based on a volumetric receptive field around a 3D depth candidate improves over using per-view 2D windows, giving the photoconsistency inference more visibility over local 3D correlations in viewpoint color aggrega-tion. Despite being trained on a standard dataset of scanned static objects, the proposed method is shown to generalize and significantly outperform existing approaches on performance capture data, while achieving competitive results on recent benchmarks.
IJCV2019submission.pdf (14.74 Mo) Télécharger le fichier
Format : Figure, Image
hal-02975479 , version 1 (22-10-2020)
Vincent Leroy, Jean-Sébastien Franco, Edmond Boyer. Volume Sweeping: Learning Photoconsistency for Multi-View Shape Reconstruction. International Journal of Computer Vision, 2021, 129, pp.284-299. ⟨10.1007/s11263-020-01377-0⟩. ⟨hal-02975479⟩
756 Consultations
300 Téléchargements
