Deep Network Classification by Scattering and Homotopy Dictionary Learning
We introduce a sparse scattering deep convolutional neural network, which provides a simple model to analyze properties of deep representation learning for classification. Learning a single dictionary matrix with a classifier yields a higher classification accuracy than AlexNet over the ImageNet 2012 dataset. The network first applies a scattering transform that linearizes variabilities due to geometric transformations such as translations and small deformations. A sparse l1 dictionary coding reduces intra-class variability while preserving class separation through projections over unions of linear spaces. It is implemented in a deep convolutional network with a homotopy algorithm having an exponential convergence. A convergence proof is given in a general framework that includes ALISTA. Classification results are analyzed on ImageNet.
deep_network_classification_by_scattering_and_homotopy_dictionary_learning_iclr_2020.pdf (642.98 Ko)
Télécharger le fichier
