Sub-sampling for Efficient Non-Parametric Bandit Exploration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we propose the first multi-armed bandit algorithm based on re-sampling that achieves asymptotically optimal regret simultaneously for different families of arms (namely Bernoulli, Gaussian and Poisson distributions). Unlike Thompson Sampling which requires to specify a different prior to be optimal in each case, our proposal RB-SDA does not need any distribution-dependent tuning. RB-SDA belongs to the family of Sub-sampling Duelling Algorithms (SDA) which combines the sub-sampling idea first used by the BESA [1] and SSMC [2] algorithms with different sub-sampling schemes. In particular, RB-SDA uses Random Block sampling. We perform an experimental study assessing the flexibility and robustness of this promising novel approach for exploration in bandit models.
sda_hal.pdf (551 Ko) Télécharger le fichier
hal-02977552 , version 1 (26-10-2020)
Dorian Baudry, Emilie Kaufmann, Odalric-Ambrym Maillard. Sub-sampling for Efficient Non-Parametric Bandit Exploration. NeurIPS 2020, Dec 2020, Vancouver, Canada. ⟨hal-02977552⟩
337 Consultations
181 Téléchargements
