Online Versus Offline NMT Quality: An In-depth Analysis on English–German and German–English - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We conduct in this work an evaluation study comparing offline and online neural machine translation architectures. Two sequence-to-sequence models: convolutional Pervasive Attention (Elbayad et al., 2018) and attention-based Transformer (Vaswani et al., 2017) are considered. We investigate, for both architectures, the impact of online decoding constraints on the translation quality through a carefully designed human evaluation on English-German and German-English language pairs, the latter being particularly sensitive to latency constraints. The evaluation results allow us to identify the strengths and shortcomings of each model when we shift to the online setup.
Error_Analysis__COLING2020_-3.pdf (438.47 Ko) Télécharger le fichier
hal-02991539 , version 1 (06-11-2020)
Maha Elbayad, Michael Ustaszewski, Emmanuelle Esperança-Rodier, Francis Brunet-Manquat, Jakob Verbeek, et al.. Online Versus Offline NMT Quality: An In-depth Analysis on English–German and German–English. COLING 2020 - 28th International Conference on Computational Linguistics, Dec 2020, Virtual, Spain. pp.5047-5058, ⟨10.18653/v1/2020.coling-main.443⟩. ⟨hal-02991539⟩
134 Consultations
177 Téléchargements
