Biased Opinion Dynamics: When the Devil is in the Details - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We investigate opinion dynamics in multi-agent networks when a bias toward one of two possible opinions exists; for example, reflecting a status quo vs a superior alternative. Starting with all agents sharing an initial opinion representing the status quo, the system evolves in steps. In each step, one agent selected uniformly at random adopts the superior opinion with some probability α, and with probability 1 − α it follows an underlying update rule to revise its opinion on the basis of those held by its neighbors. We analyze convergence of the resulting process under two well-known update rules, namely majority and voter. The framework we propose exhibits a rich structure, with a non-obvious interplay between topology and underlying update rule. For example, for the voter rule we show that the speed of convergence bears no significant dependence on the underlying topology, whereas the picture changes completely under the majority rule, where network density negatively affects convergence. We believe that the model we propose is at the same time simple, rich, and modular, affording mathematical characterization of the interplay between bias, underlying opinion dynamics, and social structure in a unified setting.
2008.13589.pdf (746.44 Ko) Télécharger le fichier
hal-03007205 , version 1 (11-12-2020)
Aris Anagnostopoulos, Luca Becchetti, Emilio Cruciani, Francesco Pasquale, Sara Rizzo. Biased Opinion Dynamics: When the Devil is in the Details. IJCAI 2020 - 29th International Joint Conference on Artificial Intelligence, Jul 2020, Yokohama, Japan. pp.53-59, ⟨10.24963/ijcai.2020/8⟩. ⟨hal-03007205⟩
77 Consultations
82 Téléchargements
