Towards Linking Diffusion MRI based Macro-and Microstructure Measures with Cortico-Cortical Transmission in Brain Tumor Patients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue NeuroImage Année : 2021
We aimed to link macro-and microstructure measures of brain white matter obtained from diffusion MRI with effective connectivity measures based on a propagation of cortico-cortical evoked potentials induced with intrasurgical direct electrical stimulation. For this, we compared streamline lengths and log-transformed ratios of streamlines computed from presurgical diffusion-weighted images, and the delays and amplitudes of N1 peaks recorded intrasurgically with electrocorticography electrodes in a pilot study of 9 brain tumor patients. Our results showed positive correlation between these two modalities in the vicinity of the stimulation sites (Pearson coefficient 0.54±0.13 for N1 delays, and 0.47±0.23 for N1 amplitudes), which could correspond to the neural propagation via U-fibers. In addition, we reached high sensitivities (0.78±0.07) and very high specificities (0.93±0.03) in a binary variant of our comparison. Finally, we used the structural connectivity measures to predict the effective connectivity using a multiple linear regression model, and showed a significant role of brain microstructure-related indices in this relation.
main.pdf (13.1 Mo) Télécharger le fichier
hal-03015641 , version 1 (19-11-2020)
Patryk Filipiak, Fabien Almairac, Théodore Papadopoulo, Denys Fontaine, Lydiane Mondot, et al.. Towards Linking Diffusion MRI based Macro-and Microstructure Measures with Cortico-Cortical Transmission in Brain Tumor Patients. NeuroImage, inPress, ⟨10.1016/j.neuroimage.2020.117567⟩. ⟨hal-03015641⟩
62 Consultations
60 Téléchargements
