A Molecular Communication Scheme to Estimate the State of Biochemical Processes on a Lab-on-a-Chip - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A key application of advanced spectroscopy methods is to estimate equilibrium states of biochemical processes in situ and in vivo. Nevertheless, an often present difficulty is the requirement that the biochemical process and its environment (such as the substrate) satisfy special conditions. One means of resolving this issue is to communicate information about the equilibrium states of the biochemical process to another location, supported via microfluidic channles within a lab-on-a-chip. In this paper, we develop a signaling strategy and estimation algorithms for equilibrium states of a biochemical process. For a toggle-switch circuit model important in cellular differentiation studies, we study via simulation the tradeoff between the rate of obtaining spectroscopy measurements and the estimation error, providing insights into requirements of spectroscopy devices for high-throughput biological assays. CCS CONCEPTS • Applied computing → Health care information systems; • Computing methodologies → Model verification and validation; Mixture modeling.
NANOCOCOA_2020_Akdeniz_Egan_ES.pdf (646.8 Ko) Télécharger le fichier
hal-03018289 , version 1 (24-11-2020)
Bayram Cevdet Akdeniz, Malcolm Egan. A Molecular Communication Scheme to Estimate the State of Biochemical Processes on a Lab-on-a-Chip. NanoCoCoA 2020 - 1st ACM International Workshop on Nanoscale Computing, Communication, and Applications, Nov 2020, Virtual Event, Japan. pp.1-6, ⟨10.1145/3416006.3431272⟩. ⟨hal-03018289⟩
47 Consultations
80 Téléchargements
