Restarted Bayesian Online Change-point Detector achieves Optimal Detection Delay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Odalric-Ambrym Maillard
In this paper, we consider the problem of sequential change-point detection where both the changepoints and the distributions before and after the change are assumed to be unknown. For this problem of primary importance in statistical and sequential learning theory, we derive a variant of the Bayesian Online Change Point Detector proposed by (Fearnhead & Liu, 2007) which is easier to analyze than the original version while keeping its powerful message-passing algorithm. We provide a non-asymptotic analysis of the false-alarm rate and the detection delay that matches the existing lower-bound. We further provide the first explicit high-probability control of the detection delay for such approach. Experiments on synthetic and realworld data show that this proposal outperforms the state-of-art change-point detection strategy, namely the Improved Generalized Likelihood Ratio (Improved GLR) while compares favorably with the original Bayesian Online Change Point Detection strategy.
paper.pdf (646.81 Ko) Télécharger le fichier
SupplementaryMaterials_BOCPD_ICML2020.zip (1.76 Mo) Télécharger le fichier
supp.pdf (314 Ko) Télécharger le fichier
hal-03021712 , version 1 (24-11-2020)
  • HAL Id : hal-03021712 , version 1
Réda Alami, Odalric-Ambrym Maillard, Raphael Féraud. Restarted Bayesian Online Change-point Detector achieves Optimal Detection Delay. International Conference on Machine Learning, Jul 2020, Wien, Austria. ⟨hal-03021712⟩
92 Consultations
125 Téléchargements
