A Neural Network with Adversarial Loss for Light Field Synthesis from a Single Image - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper describes a lightweight neural network architecture with an adversarial loss for generating a full light field from one single image. The method is able to estimate disparity maps and automatically identify occluded regions from one single image thanks to a disparity confidence map based on forward-backward consistency checks. The disparity confidence map also controls the use of an adversarial loss for occlusion handling. The approach outperforms reference methods when trained and tested on light field data. Besides, we also designed the method so that it can efficiently generate a full light field from one single image, even when trained only on stereo data. This allows us to generalize our approach for view synthesis to more diverse data and semantics.
VISAPP.pdf (10.12 Mo) Télécharger le fichier
hal-03024210 , version 1 (25-11-2020)
hal-03024210 , version 2 (17-05-2021)
  • HAL Id : hal-03024210 , version 2
Simon Evain, Christine Guillemot. A Neural Network with Adversarial Loss for Light Field Synthesis from a Single Image. VISAPP 2021 - 16th International Conference on Computer Vision Theory and Applications, Feb 2021, Vienna, Austria. pp.1-10. ⟨hal-03024210v2⟩
208 Consultations
88 Téléchargements
