The StakeCube blockchain : Instantiation, Evaluation & Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Antoine Durand
Guillaume Hébert
  • Fonction : Auteur
  • PersonId : 1082902
Khalifa Toumi
Blockchains have seen a recent rise in popularity as a generic solution for trustless distributed applications across a wide range of industries. However, blockchain protocols have faced scalability issues in applications involving a growing number of participants. In this paper we instantiate and evaluate StakeCube, a proposal for a scalable shard-based distributed ledger. We further detail and tune a byzantine agreement algorithm suited for StakeCube's sharding structure, and we experimentally study and asses its performance, especially regarding scalability. We were successfully able to run StakeCube with up to 5000 participants, confirming up to 1100 bytes/s of transaction, with a confirmation time starting at 200 seconds. Finally, we use StakeCube in a large scale energy marketplace application, and show that a node running on a Raspberry Pi Zero is able to handle the load without issues.
main.pdf (149.47 Ko) Télécharger le fichier
hal-03024408 , version 1 (25-11-2020)
  • HAL Id : hal-03024408 , version 1
Antoine Durand, Guillaume Hébert, Khalifa Toumi, Gérard Memmi, Emmanuelle Anceaume. The StakeCube blockchain : Instantiation, Evaluation & Applications. BCCA 2020 - International Conference on Blockchain Computing and Applications, Nov 2020, Virtual, Turkey. pp.1-8. ⟨hal-03024408⟩
379 Consultations
235 Téléchargements
