Enhancing Diversity in Teacher-Student Networks via Asymmetric branches for Unsupervised Person Re-identification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The objective of unsupervised person re-identification (Re-ID) is to learn discriminative features without laborintensive identity annotations. State-of-the-art unsupervised Re-ID methods assign pseudo labels to unlabeled images in the target domain and learn from these noisy pseudo labels. Recently introduced Mean Teacher Model is a promising way to mitigate the label noise. However, during the training, self-ensembled teacher-student networks quickly converge to a consensus which leads to a local minimum. We explore the possibility of using an asymmetric structure inside neural network to address this problem. First, asymmetric branches are proposed to extract features in different manners, which enhances the feature diversity in appearance signatures. Then, our proposed cross-branch supervision allows one branch to get supervision from the other branch, which transfers distinct knowledge and enhances the weight diversity between teacher and student networks. Extensive experiments show that our proposed method can significantly surpass the performance of previous work on both unsupervised domain adaptation and fully unsupervised Re-ID tasks.
0067.pdf (1.49 Mo) Télécharger le fichier
hal-03028661 , version 1 (27-11-2020)
  • HAL Id : hal-03028661 , version 1
Hao Chen, Benoit Lagadec, Francois F Bremond. Enhancing Diversity in Teacher-Student Networks via Asymmetric branches for Unsupervised Person Re-identification. WACV 2021 – IEEE Winter Conference on Applications of Computer Vision, Jan 2021, Waikoloa / Virtual, United States. ⟨hal-03028661⟩
50 Consultations
51 Téléchargements
