A Dataset Complexity Measure for Analogical Transfer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Analogical transfer consists in leveraging a measure of similarity between two situations to predict the amount of similarity between their outcomes. Acquiring a suitable similarity measure for analogical transfer may be difficult, especially when the data is sparse or when the domain knowledge is incomplete. To alleviate this problem, this paper presents a dataset complexity measure that can be used either to select an optimal similarity measure, or if the similarity measure is given, to perform analogical transfer: among the potential outcomes of a new situation, the most plausible is the one which minimizes the dataset complexity.
ijcai-final.pdf (721.75 Ko) Télécharger le fichier
hal-03029949 , version 1 (29-11-2020)
  • HAL Id : hal-03029949 , version 1
Fadi Badra. A Dataset Complexity Measure for Analogical Transfer. International Joint Conference on Artificial Intelligence, Jan 2021, Kyoto, Japan. ⟨hal-03029949⟩
156 Consultations
100 Téléchargements
