Attack on LAC Key Exchange in Misuse Situation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
LAC is a Ring Learning With Error based cryptosystem that has been proposed to the NIST call for post-quantum standardization and passed the rst round of the submission process. The particularity of LAC is to use an error-correction code ensuring a high security level with small key sizes and small ciphertext sizes. LAC team proposes a CPA secure cryptosystem, LAC.CPA, and a CCA secure one, LAC.CCA, obtained by applying the Fujisaki-Okamoto transformation on LAC.CPA. In this paper, we study the security of LAC Key Exchange (KE) mechanism, using LAC.CPA, in a misuse context: when the same secret key is reused for several key exchanges and an active adversary has access to a mismatch oracle. This oracle indicates information on the possible mismatch at the end of the KE protocol. In this context, we show that an attacker needs at most 8 queries to the oracle to retrieve one coecient of a static secret key. This result has been experimentally conrmed using the reference and optimized implementations of LAC. Since our attack can break the CPA version in a misuse context, the Authenticated KE protocol, based on the CCA version, is not impacted. However, this research provides a tight estimation of LAC resilience against this type of attacks.
misuseAttackLAC.pdf (472.11 Ko) Télécharger le fichier
hal-03046345 , version 1 (08-12-2020)
  • HAL Id : hal-03046345 , version 1
Aurélien Greuet, Simon Montoya, Guénaël Renault. Attack on LAC Key Exchange in Misuse Situation. CANS 2020 - 19th International conference on Cryptology and Network Security, Dec 2020, Vienna, Austria. ⟨hal-03046345⟩
80 Consultations
219 Téléchargements
