MemOpLight: Leveraging application feedback to improve container memory consolidation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The container mechanism amortizes costs by consolidating several servers onto the same machine, while keeping them mutually isolated. Specifically, to ensure performance isolation, Linux relies on memory limits. These limits are static, despite the fact that application needs are dynamic; this results in poor performance. To solve this issue, MemOpLight uses dynamic application feedback to rebalance physical memory allocation between containers focusing on under-performing ones. This paper presents the issues, explains the design of MemOpLight, and validates it experimentally. Our approach increases total satisfaction by 13% compared to the default.
nca.pdf (8.22 Mo) Télécharger le fichier
hal-03065629 , version 1 (14-12-2020)
Francis Laniel, Damien Carver, Julien Sopena, Franck Wajsburt, Jonathan Lejeune, et al.. MemOpLight: Leveraging application feedback to improve container memory consolidation. NCA 2020 - 19th IEEE International Symposium on Network Computing and Applications, Nov 2020, Cambridge / Virtual, United States. pp.1-10, ⟨10.1109/NCA51143.2020.9306717⟩. ⟨hal-03065629⟩
178 Consultations
54 Téléchargements
