Deeply Transformed Subspace Clustering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Signal Processing Année : 2020
Subspace clustering assumes that the data is separable into separate subspaces; this assumption may not always hold. For such cases, we assume that, even if the raw data is not separable into subspaces, one can learn a deep representation such that the learnt representation is separable into subspaces. To achieve the intended goal, we embed subspace clustering techniques (locally linear manifold clustering, sparse subspace clustering and low rank representation) into deep transform learning. The entire formulation is jointly learnt; giving rise to a new class of methods called deeply transformed subspace clustering (DTSC). To test the performance of the proposed techniques, benchmarking is performed on image clustering problems. Comparison with state-of-the-art clustering techniques shows that our formulation improves upon them.
DTSC complete.pdf (280.15 Ko) Télécharger le fichier
hal-03066160 , version 1 (15-12-2020)
Jyoti Maggu, Angshul Majumdar, Emilie Chouzenoux, Giovanni Chierchia. Deeply Transformed Subspace Clustering. Signal Processing, 2020, 174, pp.107628. ⟨10.1016/j.sigpro.2020.107628⟩. ⟨hal-03066160⟩
50 Consultations
163 Téléchargements
