A Dataset Independent Set of Baselines for Relation Prediction in Argument Mining - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Argument Mining is the research area which aims at extracting argument components and predicting argumentative relations (i.e.,support and attack) from text. In particular, numerous approaches have been proposed in the literature to predict the relations holding between the arguments, and application-specific annotated resources were built for this purpose. Despite the fact that these resources have been created to experiment on the same task, the definition of a single relation prediction method to be successfully applied to a significant portion of these datasets is an open research problem in Argument Mining. This means that none of the methods proposed in the literature can be easily ported from one resource to another. In this paper, we address this problem by proposing a set of dataset independent strong neural baselines which obtain homogeneous results on all the datasets proposed in the literature for the argumentative relation prediction task. Thus, our baselines can be employed by the Argument Mining community to compare more effectively how well a method performs on the argumentative relation prediction task.
Informatique
hal-03067403 , version 1 (15-12-2020)
Oana Cocarascu, Elena Cabrio, Serena Villata, Francesca Toni. A Dataset Independent Set of Baselines for Relation Prediction in Argument Mining. 2020. ⟨hal-03067403⟩
57 Consultations
0 Téléchargements
