On the persistent homology of almost surely $C^0$ stochastic processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied and Computational Topology Année : 2023
This paper investigates the propreties of the persistence diagrams stemming from almost surely continuous random processes on [0, t]. We focus our study on two variables which together characterize the barcode : the number of points of the persistence diagram inside a rectangle ] −∞, x] × [x + ε, ∞[, N x,x+ε and the number of bars of length ≥ ε, N ε. For processes with the strong Markov property, we show both of these variables admit a moment generating function and in particular moments of every order. Switching our attention to semimartingales, we show the asymptotic behaviour of N ε and N x,x+ε as ε → 0 and of N ε as ε → ∞. Finally, we study the repercussions of the classical stability theorem of barcodes and illustrate our results with some examples, most notably Brownian motion and empirical functions converging to the Brownian bridge.
P2new.pdf (562.43 Ko) Télécharger le fichier
hal-03079171 , version 1 (17-12-2020)
hal-03079171 , version 2 (03-07-2023)
Daniel Perez. On the persistent homology of almost surely $C^0$ stochastic processes. Journal of Applied and Computational Topology, 2023, ⟨10.1007/s41468-023-00132-x⟩. ⟨hal-03079171v2⟩
57 Consultations
56 Téléchargements
