Multipatch isogeometric mortar methods for thick shells - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2020
This paper introduces, analyzes and validates isogeometric mortar methods for the solution of thick shells problems which are set on a multipatch geometry. A particular attention will be devoted to the introduction of a proper formulation of the coupling conditions, with a particular interest on augmented lagrangian formulations, to the choice and validation of mortar spaces, and to the derivation of adequate integration rules. The relevance of the proposed approach is assessed numerically on various significative examples.
Article_Multi-patch_V7.pdf (7.18 Mo) Télécharger le fichier
hal-03088221 , version 1 (25-12-2020)
Nicolas Adam, Patrick Le Tallec, Malek Zarroug. Multipatch isogeometric mortar methods for thick shells. Computer Methods in Applied Mechanics and Engineering, 2020, 372, pp.113403. ⟨10.1016/j.cma.2020.113403⟩. ⟨hal-03088221⟩
91 Consultations
50 Téléchargements
