MRI Vocal Tract Sagittal Slices Estimation during Speech Production of CV - Archive ouverte HAL Access content directly
Conference Papers Year :
(1) , (1) , (2) , (3) , (4) , (5) , (5) , (1)
1
2
3
4
5
In this paper we propose an algorithm for estimating vocal tract para sagittal slices in order to have a better overview of the behaviour of the articulators during speech production. The first step is to align the consonant-vowel (CV) data of the sagittal plains between them for the train speaker. Sets of transformations that connect the midsagittal frames with the neighbouring ones is acquired for the train speaker. Another set of transformations is calculated which transforms the midsagittal frames of the train speaker to the corresponding midsagittal frames of the test speaker and is used to adapt to the test speaker domain the previously computed sets of transformations. The newly adapted transformations are applied to the midsagittal frames of the test speaker in order to estimate the neighbouring sagittal frames. Several mono speaker models are combined to produce the final frame estimation. To evaluate the results, image cross-correlation between the original and the estimated frames was used. Results show good agreement between the original and the estimated frames.
3D_EUSIPCO_2020.pdf (305.48 Ko) Télécharger le fichier
Dates and versions
hal-03090824 , version 1 (30-12-2020)
Identifiers
Cite
Ioannis K Douros, Ajinkya Kulkarni, Yu Xie, Chrysanthi Dourou, Jacques Felblinger, et al.. MRI Vocal Tract Sagittal Slices Estimation during Speech Production of CV. EUSIPCO 2020 - 28th European Signal Processing Conference, Jan 2021, Amsterdam / Virtual, Netherlands. ⟨10.23919/Eusipco47968.2020.9287834⟩. ⟨hal-03090824⟩
125 View
169 Download
Share
