On the induced geometry on surfaces in 3D contact sub-Riemannian manifolds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2022
Given a surface S in a 3D contact sub-Riemannian manifold M, we investigate the metric structure induced on S by M, in the sense of length spaces. First, we define a coefficient at characteristic points that determines locally the characteristic foliation of S. Next, we identify some global conditions for the induced distance to be finite. In particular, we prove that the induced distance is finite for surfaces with the topology of a sphere embedded in a tight coorientable distribution, with isolated characteristic points.
hal-03091917 , version 1 (31-12-2020)
Davide Barilari, Ugo Boscain, Daniele Cannarsa. On the induced geometry on surfaces in 3D contact sub-Riemannian manifolds. ESAIM: Control, Optimisation and Calculus of Variations, 2022, 28 (9). ⟨hal-03091917⟩
76 Consultations
0 Téléchargements
