A time domain factorization method for obstacles with impedance boundary conditions - Archive ouverte HAL Access content directly
Journal Articles Inverse Problems Year : 2020
(1) , (1)
1
Houssem Haddar
Xiaoli Liu
  • Function : Author
  • PersonId : 994313
We consider the inverse acoustic time domain scattering problem for absorbing scatterers modeled by impedance boundary conditions. We present and analyze a factorization method for reconstructing the obstacle boundary from far field measurements. The analysis is based on using the Laplace transform and proving the coercivity of the solution operator in suitable weighted spaces in time. This leads us to consider a modified far field operator parameterized by the imaginary part of Laplace variable which is different but can be arbitrarily close to the original far field operator. As a proof of concept we also provide some preliminary numerical examples to test and discuss the effectiveness of the resulting inversion method when applied to the original far field operator.
Not file
Dates and versions
hal-03092782 , version 1 (02-01-2021)
Identifiers
Cite
Houssem Haddar, Xiaoli Liu. A time domain factorization method for obstacles with impedance boundary conditions. Inverse Problems, 2020, 36 (10), pp.105011. ⟨10.1088/1361-6420/abaf3b⟩. ⟨hal-03092782⟩
77 View
0 Download
Share
