metric-learn: Metric Learning Algorithms in Python - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2020
William de Vazelhes
  • Fonction : Auteur
  • PersonId : 1087685
Cj Carey
  • Fonction : Auteur
Yuan Tang
  • Fonction : Auteur
Nathalie Vauquier
  • Fonction : Auteur
  • PersonId : 1087686
metric-learn is an open source Python package implementing supervised and weaklysupervised distance metric learning algorithms. As part of scikit-learn-contrib, it provides a unified interface compatible with scikit-learn which allows to easily perform cross-validation, model selection, and pipelining with other machine learning estimators. metric-learn is thoroughly tested and available on PyPi under the MIT license.
jmlr20.pdf (693.71 Ko) Télécharger le fichier
hal-03100076 , version 1 (06-01-2021)
  • HAL Id : hal-03100076 , version 1
William de Vazelhes, Cj Carey, Yuan Tang, Nathalie Vauquier, Aurélien Bellet. metric-learn: Metric Learning Algorithms in Python. Journal of Machine Learning Research, 2020, 21, pp.1-6. ⟨hal-03100076⟩
84 Consultations
366 Téléchargements
