Algorithms for cable-suspended payload sway damping by vertical motion of the pivot base - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mechanical Systems and Signal Processing Année : 2021
The solution of a case study problem of suspended payload sway damping by moving a pivot base in vertical direction is presented. Unlike for the classical problem of anti-sway control for moving the base in the horizontal direction, implemented e.g. in cranes, a direct solution by using control feedback theory for linear systems is not possible. Once the model is linearized, it becomes uncontrollable. Thus, a derivation of a nonlinear controller is needed to solve the task. In this context, two solutions are proposed. The first solution is based on imposing harmonic motion of the base with double frequency of the payload natural frequency. Synchronization of the base and the payload deflection angle is done either by proportional time-delay controller or by proportional-derivative delay free controller. Secondly, the Lyapunov’s second method is directly applied to derive a nonlinear controller. For both cases, balancing the dissipated energy, rules for determining equivalent damping are explicitly derived. After discussing and solving the corresponding implementation aspects, both simulation and experimental validations are performed. The experimental validation is performed on a simplified problem, where only horizontal motion is possible. The simulation based validation is performed on a nonlinear two dimensional model of a quadcopter carrying a suspended payload.
HAL-Kure-et-al-MSSP-2021.pdf (1.41 Mo) Télécharger le fichier
hal-03108536 , version 1 (06-05-2021)
Matěj Kuře, Jaroslav Bušek, Tomas Vyhlidal, Silviu-Iulian Niculescu. Algorithms for cable-suspended payload sway damping by vertical motion of the pivot base. Mechanical Systems and Signal Processing, 2021, 149, pp.107131. ⟨10.1016/j.ymssp.2020.107131⟩. ⟨hal-03108536⟩
97 Consultations
234 Téléchargements
