Triangulating submanifolds: An elementary and quantified version of Whitney’s method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Computational Geometry Année : 2020
Trianguler les sous-variétés: une version élémentaire et quantifiée de la méthode de Whitney
We quantize Whitney's construction to prove the existence of a triangulation for any C^2 manifold, so that we get an algorithm with explicit bounds. We also give a new elementary proof, which is completely geometric.
WhitneyDCGfinal.pdf (401.27 Ko) Télécharger le fichier
hal-03109814 , version 1 (14-01-2021)
Jean-Daniel Boissonnat, Siargey Kachanovich, Mathijs Wintraecken. Triangulating submanifolds: An elementary and quantified version of Whitney’s method. Discrete and Computational Geometry, 2020, ⟨10.1007/s00454-020-00250-8⟩. ⟨hal-03109814⟩
92 Consultations
135 Téléchargements
