Maximum likelihood estimation for spinal-structured trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
We investigate some aspects of the problem of the estimation of birth distributions (BD) in multi-type Galton-Watson trees (MGW) with unobserved types. More precisely, we consider two-type MGW called spinal-structured trees. This kind of tree is characterized by a spine of special individuals whose BD $\nu$ is different from the other individuals in the tree (called normal whose BD is denoted $\mu$). In this work, we show that even in such a very structured two-type population, our ability to distinguish the two types and estimate $\mu$ and $\nu$ is constrained by a trade-off between the growth-rate of the population and the similarity of $\mu$ and $\nu$. Indeed, if the growth-rate is too large, large deviations events are likely to be observed in the sampling of the normal individuals preventing us to distinguish them from special ones. Roughly speaking, our approach succeeds if $r<\mathfrak{D}(\mu,\nu)$ where $r$ is the exponential growth-rate of the population and $\mathfrak{D}$ is a divergence measuring the dissimilarity between $\mu$ and $\nu$.
paper.pdf (1.35 Mo) Télécharger le fichier
Licence : CC BY - Paternité
hal-03109867 , version 1 (23-01-2024)
Romain Azaïs, Benoît Henry. Maximum likelihood estimation for spinal-structured trees. 2024. ⟨hal-03109867⟩
84 Consultations
4 Téléchargements
